I need help to delete DPF.
Fiat Ducato 2,3l
Ecu MJD 8F3.B1
Davinci don't work.
Thank you
Fiat Ducato 2,3l
Ecu MJD 8F3.B1
Davinci don't work.
Thank you
here solution with davinci original must work
pass pm
EngineGen is a robber : Dmitry Tolmachev !!!!! Be careful guys !!! this guy sucked me 180 euros ....
disconnect temp and diff sensors
matt1781 (25th February, 2024)
I made a file error
Here is the correct file.
Hi all members DK,
It's possible to delete DPF of my file FLASH MJD 8F3.
Thank you,
try and report
matt1781 (26th February, 2024)
here no pass
matt1781 (28th February, 2024)
I have a big problem injecting the Farawhy1 file.
The vehicle has an idle speed that accelerates up to 3000 rpm.
Is there anything to do?
Can anyone check the file?
Thanks,
