Results 1 to 15 of 26
    matekhr's Avatar
    Croatia
    Default Mercedes C220 (W202) im*o off possible?
    I have problems with this car. Car don't start, only two leds (red and green) on reverse mirror are flashing. It's 1996. petrol engine C220 with VDO engine ECU.
    Here I have original dumps from ECU, im*o box and key.
    Can anybody help me with im*o-off solution?
    Thanks in advance.
    Best regards
    Check batterie off the key first.
    try this and let's know, meanwhile remember to say thx
    Tale care, last week have one in my garage same problems exactly, and was a relay for the radiator fans..........fans works all time unless you remove the key?
    I replace the relay and all worked again.
    matekhr's Avatar
    Croatia
    Quote Originally Posted by GolfmkI View Post
    No, fans are not working. Car only cranks, but not start.
    two things to check 1 look at the front of the key and if you hold down the button can you see red light.
    2 if the car has interior sensors left and right then it has optional alarm which gooes wrong. if so remove passenger side front carpet you will see metal bracket pull down and remove extra alarm you will see the bridge for the reciver put back to original state.
    shoul work then.
    if you need any more info let me know
    matekhr's Avatar
    Croatia
    Quote Originally Posted by simon77 View Post
    shoul work then.
    1. yes, there is red light. IR diode is working, too.
    2. I'll check, I don't know if there is alarm.
    Thanks for your answer.
    Hel , the first , i want to know your key can remote ? start the car and the mirror red & green light flash , the problem is ata can not connect ecu , or ata is lock mode . detail to ask me and i can help u ...
    E-mail : harry@harryauto.com
    Harry
    Croatia europe
    Quote Originally Posted by matekhr View Post
    Thanks in advance.
    Best regards
    well my friend..these car is worked out in so many variations..some of them have only IR but in this year I think there is also transponder inside key?..remove carpet (coodriver foot area) and there you will found all what you need to know..post here all details ..central lock work via remote ?
    regards from ex elprog member
    jackeldestripador's Avatar
    S.A.
    so makekhr... did the files given to you from sogaro worked? i have the same problem as you with C220. if you want i can post bin files...
    Pllz let me know. thanks in advance
    Quote Originally Posted by jackeldestripador View Post
    is the dump for immo or ecu?
    br
    matekhr's Avatar
    Croatia
    I didn't make it work.
    I use only im*o file given by Sogaro (HC05), because I have 24c01 eeprom in ECU and not HC11E9, so I was unable to use this file. I tried everything described here, but without success.
    I think I'll give up, I spent too much time for nothing...
  13. #13
    hi
    last week i have same problem with a W210, 1996 with diesel engine, when i scan it with the Star, there is no communication between IFZ and ECU (no CAN communication), to shek this, you have to read KI's failure memory and look if you have not communication with ECU
    regards
  14. #14
    workshop
    immobox death,
  15. #15
    step by step instructions to snc my new key on my w202 c220 96 model merc please
