    Sep 2016
    Hungary
    Default Ford transit bcm
    hy ford transit bcm right turn signal not working can anyone help?
    bcm number:CC1T-14A073-CC
    fault code:
    B1D07:11-0A
    U3000:49-48
    thx
    rob h's Avatar
    May 2011
    Reflash it, with Ford online. It might reset it. Have had some succes with drl that would not work. After update, they came back to life.
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by rob h View Post
    online programming will "not" clear u3000 error, i did try it but no...
    edit
    i see now you have other then the 64kb d-flash so maybe it can be done as suggested bij robH
    also read this:
    https://www.digital-kaos.co.uk/forums/showthread.php/1074354-Ford-Tranzit-Custom-BCM-U3000-49-error?p=4701299&viewfull=1#post4701299
    ...write this ok eeprom,done 2 key learning and initialization module...
  5. The Following User Says Thank You to stas12 For This Useful Post:
    kismurmi (3rd March, 2024)
    ricked's Avatar
    Apr 2016
    Europe
    here is a good error free eeprom, but you need to code everything again online
  7. The Following 2 Users Say Thank You to ricked For This Useful Post:
    Hack01 (25th April, 2024), kismurmi (3rd March, 2024)
  8. #6
    Hello, I have a similar problem, turn signals not working. Can someone fix the dump?
