Results 1 to 8 of 8
    Aug 2015
    Default polo tsi med 17.5.25 immo off needed
    hi all, please could someone immo off or transfer immo data.
    attached original ecu and donor ecu files.
    vw AG 04E 907 309 AF
    MED 17.5.25
    thanks kindly
    Aug 2015
    hi , anyone
    Hayssam1's Avatar
    Germany
    Quote Originally Posted by andys1977 View Post
    MED 17.5.25
    thanks kindly
    immo off for 2 ECU eeprom off and flesh off and transfer immo data neu eeprom
    VIN: AAVZZZ6RZHU105743
    CS: 73659C66DA4568
    MAC: 90C2F71A
    PIN: 02093
    Please Press Thanks Button and Reput if i helped !
  4. The Following User Says Thank You to Hayssam1 For This Useful Post:
    andys1977 (14th March, 2024)
    Aug 2015
    hi there, thanks for your help
    i tried with your donor files but car starts once , when switched off wont start again
    not sure if the original eeprom file is corrupted. i will upload a read i did in 2022 for the same ecu
    please check for me
    thanks kindly
    Hayssam1's Avatar
    Germany
    immo off ...........
    South Africa
    hi friend. try these files immo off. flash and eeprom
    Aug 2015
    @frikki , thanks, but wrong files used
    richard27's Avatar
    Aug 2011
    Default can you try this
    if you haven't tried it before+++++good luck
    ​information sharing
