probe tis.
Regards.
i have a ECU from fiat punto IAW 59F M3 HW303 1080-OMZ.
I want read out this ecu with my kwp2000+ flasher and the Software "Decode Marelli", here from this side.
I Pin out my ECU
12+ on PIN 4 and 17
K-Line on PIN 16
Ground over Chassis
on my OBD Flasher
PIN7 K-LINE
PIN16 12+
PIN5 ground
To bring my ECU in boot mode, i turn 12+ off, bridge ground point, turn 12+ on.
I start Decode Marelli, kick was found. When i klick Data, no eco found.
What is here wrong?
I start the Software KWP2000+, i can read ECU data.. i cant read or write with this soft???
What is here wrong???
I have a File for 59F M3 HW303 with cleard im*o ( no code), this was 304 kb. How can i write this file into my ecu?
When i read out my ECU with galletto 1250 in normale mode is the file 256kb small. I can read and write this file.
I read out my ECU in boot mode with galletto, is the file 320 kb big. i cant write this file back into my ecu. eobd2 soft say "wrong port speed"
what can i do to write my 304 kb file with cleard im*o in my ecu.
I testet a lot of Software with my KWP2000+ Flasher
- Decode marelli - do not work, found no ECU
- 59F-5AF boot - do not work, found no ECU. Klick i KWP2000, i can read ECU Info. No read or write funktion
- KWP2000+ Ultility - i can read ECU Info (Screenshot), read or write funktion dosnt work
Please help me!
thx
PS: sorry for my bad english
probe tis.
Regards.
Thx for your answer!
boot mode and PIN OUT is right.... Software or Flasher dont work
I need help with an IAW 16F.EB
with M 27C512.....how can I get off inmo****
for to read and make immo off for this ecu ,she need's another interface communication with tunining interface i have it if you can read post your dump i make it for you
my problem is, i can?t read out my ecu in boot mode with kwp2000!
I can read out it in normal mode - filesize 256 kb
i can read out in boot mode with galletto 1250 - filesize 320 kb. i can?t write this file back. programmer say "wrong port speed"
@nany,
what filesize your need from my ecu?
thx
now i can read and write in boot mode with another mode from my Galletto software.
Filesize is 320 kb.
Can you clear immo of with my file?
There is lots of post on this forum about this ecu and i try many times to do this with galletto and kwp but never get to work if you use galletto and it works,you are to read with galletto and write back same file using CLODA E DECODE in galletto software it will decode your ecu so it will be virgin not immo off thats if does full write back, need other tool for doing immo off this is differnt tool.
Thanks kev
my question is, waht iterface (Pragrammer/Flasher) i need, to write a dump File with cleard immo (Files i have - 304 kb), with software "Decode marelli" in to my ecu IAW 59F HW303?Can you help me?
I think u have problem vith usb driver.
How windows recognise uor interface?
is not a driver problem. i testet my kwp2000+ flasher with original driver from flasher and driver from decode marelli....
Driverversion is 1.3.20.0 from cartech sas.
Windows recognise from interface is "serial to kline interface"
kwp2000+ flasher work with iaw 59F ecu < HW100 kwp2000+ software in normal mode. Filesize 256 kb.
Don?t work with "decode marelle" or "4AF Boot" or HW100>.
Is the problem + from my kwp2000+ flasher?
thx
what is beter interface flasher gallet or KWP2000
