Thread: vw caddy
    Default vw caddy
    1.9 diesel. s reg 98. been bought as salvage no key. changed ecu , key pickup and key. but still will not start, do i have to change anything else.. thanks
    z786's Avatar
    10 Steps Ahead of You
    has that one got a seperate immo or is it stored in the speedo
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    K.Kambelovac Croatia
    1.9 Diesel or TDI,SDI engine code scan fault code and post here.
    you need the ignition barrel and key, immobiliser ecu and engine ecu all off the same car if you havnt got vcds.
    or the change the ignition barrel and key, and immobiliser ecu ( off the same car ) . and then adapt your engine ecu to the new immo
    Quote Originally Posted by chrisr950 View Post
    you need the ignition barrel and key, im*obiliser ecu and engine ecu all off the same car if you havnt got vcds.
    or the change the ignition barrel and key, and im*obiliser ecu ( off the same car ) . and then adapt your engine ecu to the new im*o
    can you tell me were the immo ecu is located please
    west midlands
    the immo ecu is usually located behind the instrument panel towards the centre console. also worth checking you have glow lamp illuminated on ignition
