    Aug 2015
    Spain
    Default Opel Zafira C BCM configuration
    I have a problem with Opel Zafira C 2014 year. I changed the BCM module, because the car was flooded. The new one is learned to the car, but don't control the headlights correctly, the car is equipped with Xenon lights The BCM output not control the relay for the low beam. I cannot find any tool to configure the new BCM. I bought one more BCM from a car with Xenon ligtsm but the module acts as mine.
    How can I do configuration of the BCM ? Which tool can change the configuration of the BCM module ?
    I tried with OP Com, Autel and Launch, but there is no this option.
    Mar 2016
    Bosna i Hercegovina
    maybe try to replace the indicator switch,I've had problems with newer Opel cars where the indicator switch is faulty
    Aug 2019
    Bulgaria
    After 2012 only online account or clone NEC.
  4. The Following User Says Thank You to miroopel For This Useful Post:
    gogetit (12th April, 2024)
    Aug 2015
    Spain
    Quote Originally Posted by miroopel View Post
    Thank you for the information. Which tool must to use with online account ? I am not familiar with the Opel.
    toutougsmserver's Avatar
    Jan 2013
    inside map
    Quote Originally Posted by gogetit View Post
    need to use SPS servicebox access,is web based then you can do configuration (bcm must be set with car VIN)!
    VAG Bcm2,pcr2.1,edc17,med17,MED9.1.1 immo clone & data transfert
    PSA sid208 immo clone,synchro to bsi
    RB4,RB8 DEF FIX
    ODIS-S and E full install via remote
  7. The Following User Says Thank You to toutougsmserver For This Useful Post:
    gogetit (22nd April, 2024)
  8. #6
    Aug 2015
    Spain
    Quote Originally Posted by toutougsmserver View Post
    I tried with SPS online, but cant configure it. I start the procedure configuration + setup, follow all of the steps. The procedure finish successfuly, but the BCM module acts as previously.
    Tried with other BCM module, same thing. I tried to reprogramm it but cant recognise version of the unit and stop the process.
