Dear Transit experts,
this Transit has 2.4L diesel engine 90hp/66kW year 2004 engine code D2FE.
Original engine with ecu DPC-805
The second used diesel engine arrived with ecu DPC-635
I swapped cluster, ecu is now DPC-635, key of the second van,
the engine crank and run approx 3 seconds then die.
DTC is P0230 primary circuit fuel pump
Don't know how it works before because it arrived with original broken engine.
