Results 1 to 2 of 2
    Nov 2020
    Default Renault Duster 2017 error code
    Hi to all DK members
    I have Renault Duster ph2 the check engine light ca0me on while driving, stopped the car and scanned the error code with autel , it showed error code
    DF457( flywheel target component in poor condition), tried to erase didnt work, disconnecting battery and reconnecting failed as well.
    would replacing crank sensor solve the problem? or any other solution?
    Thanks in advance
    Jun 2023
    You can try to clean it first, there probably metalic pieces on it.
    If it would be completely dead youwill not be able to start the car anymore.
