the codes might be throwing u off abit .. l have afew of this we service for a hire company and all of them needed injector seals .. the way we test them is to jack the back end up as hi as u can and leave for an hour . if it starts its them
got a Zafira here,
customer said the car wouldnt start so he had it towed 2 the local garage,
the garage jump started the car and it worked
then the car went dead again.
Now the codes the car gave were
P0070 - Ambient Air Temperature Low Input
(02) - Present
P0340 - Camshaft Position Sensor Circuit Range/Performance
(0D) - Present
P1540 - Air Condition PWM-Signal invalid
(0D) - Not present
U2103 - CAN-Bus Node no Communication
(07) - Not present
P1612 - im*obiliser No Or Wrong Signal
(00) - Not present
P1811 - Torque Signal Malfunction (CAN)
(0A) - Not present
P1222 - Injection Pump Malfunction
(0A) - Not present
P0400 - Exhaust Gas Recirculation Valve Voltage Supply Circuit Low Input
(0E) - Not present
P0400 - Exhaust Gas Recirculation Circuit Open
(04) - Not present
they had crank sensor changed but still no joy.
i went and scanned the car, cleared codes, tried 2 start and i got these
(02) - Present
(0A) - Present
(0D) - Not present
then i cleared again and tried 2 start and got these,
now the thing is i cleared and tried 2 start 8 times after that but kept getting
(02) - Present
(0D) - Present
any help is greatly appreciated as the car is a means of livelyhood for customer
thanx
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
right im off 2 jack the car,
was the ones you had complete non starters??
Cam Sensors are common on them just to make sure you have the original sensor from the dealers.
Hope This Helps
Ash
i've had injector seal trouble on these in the past, also the cam sensors seem to be a weak part along with the wiring which tends to rub through. the last one though ended up as being filled with petrol instead of diesel
This is a good trick i will have to know how it works just by jacking it high as possible and live it for 20min and then it will start
That's something new to me
Ash
this is from a vauxhall worker :
Re: HAS ANYBODY HAD THIS TROUBLE WITH THERE ZAFIRA/VECTRA 2.0 Di DIESEL
hi mate, i used to work at vauxhall for over 6 years, the symptoms you describe, are exactly those of the injector seals leaking air, thus meaning fuel drain back to the tank, when left with the front end facing uphill. However if you've had them done, i suggest you re-check over what they've done. Every car i looked at at vauxhall was cured with the replacement of the seals. (x20dtl, y20dth, y22dth etc etc) The seals are very small, and fragile, and are easily damaged during fitment if not done correctly. If the seals are weeping/leaking, then theroeticlly the fuel should leak the other way when running, shown by either an oil fouled fuel filter, or diesel fouled engine oil (seen a few of these, if not found quickly engines can take off on their own). Another way to check is to Take a sample of fuel and see if it'd oil fouled.
One last thing, when you replaced the leak off pipes, did you replace the small plastic t-pieces too? these were also known for getting hairline cracks/splits once tampered with.
Hope this helps!
...then i cleared again and tried 2 start and got these,
(02) - Present
(0D) - Present
thanx[/QUOTE]
If reported error P 0340, i mean,that this sensor inside the diesel pumps and lacks only repair of pump.
Have you checked the Valve Timing to see if the cam belt has not jumped.
Ash
Hi,what tool are you using to scan this car?
this engine dont have cam sensor, it has a pump speed/angle sensor internal in pump.
injector seals are common as stated above, but a far better way of testing them is with a midivac vacuum hand pump, just pull of the leakoff pipes from injectors and connect vac pump, create a vacuum and if it hold vacuum there ok if vac drops off there faulty.
do dtc,s come back with just an ignition cycle or do you have to crank for a while?
you will have to check the timing aswell incase chain has jumped, but this is unlightly as it uses two small chains which has less chance of jumping but can still strech a little.
hth
right, had it jacked or an hour, parked it facing down hill, then jacked it.
still no start,
because the car was very far from my house i told them to try starting it in an hour, it didnt
@ ADTS
the dtcs come back when the car is cranked for a few seconds.
so wat u guys reckon, shud i recommend seals 2 be changed or repair pump (if repair pump, wat needs 2 be repaired) thanks as always
goin 2 bed been stuck in motorway traffic for past 4 hours
