Results 1 to 5 of 5
    trickydicky
    Guest
    Default Playing Media files.
    Hi all,
    So, I can succesfully mount a network share, and record and play recordings from my openmedia box to a hard disk drive on my PC...
    But, I cannot select any other type of media file (MPG for example) from the hard drive and successfully play that, either using movie player, or recording player. it either goes blank, or it returns to the menu.
    Which media types are supported to play, and how can I play them?
    many thanks
    Tricky
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    Quote Originally Posted by trickydicky View Post
    Hi all,
    many thanks
    Tricky
    you will need to use VLC plugin an both pc and plugin, to be able to play .avi etc.. and it gets streamed from the pc>computer,, not actually playing on the box.
    boom!
    trickydicky
    Guest
    Thanks, so I've been trying unsuccessfully to get VLC Working.. I've installed VLC on my PC etc..
    On my Openmedia box (Neutrino image), I have a menu to configure all the VLC details. But if I go to Plugins, there is no VLC plugin...
    So, my question is whether I need an additional plugin, or whether the VLC capability is already included. If I need the VLC plugin where can I get it from?
    Many Thanks
    Tricky
    Jun 2008
    Never Never Land
    Many Thanks
    Tricky
    sorry only tested on enigma, but here,( fill paths probably fona be differnet in vlc , but you will get the .so and .cfg )
    boom!
    Oct 2008
    Hi all,
    many thanks
    Tricky
    Is the recording on this better than DB500 as the DB500 chips are not great for recording but this was "fixed" on the DB600.
    Did you record with SMBFS, CIFS or NFS?
