Results 1 to 2 of 2
    rtvservis's Avatar
    Default skoda abs coding tire wrning off option pleas
    Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
    Control Module Part Number: 5Q0 907 379 A HW: 5Q0 907 379 A
    Component and/or Version: ESC H75 0333
    Software Coding: 1C07629120230A6C0080060401C6243846045000608024F000 480020C0
    Work Shop Code: WSC 73430 031 00063
    ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020 (SK37)
    ROD: EV_Brake1UDSContiMK100ESP_008.rod
    VCID: 3A2D32F51CDC670A217-806E
    1 Fault Found:
    16401 - Tire Pressure Warning
    C102D 00 [10001001] - -
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 41
    Reset counter: 178
    Mileage: 290886 km
    Date: 2024.04.22
    Time: 16:56:13
    Apr 2021
    Press and hold the TPMS button to reset TPMS or use the radio screen to reset TPMS, or use diagnostic routine to reset TPMS. If that car does not have this button or the radio screen option, then the abs coding is wrong. If that is the case, then it is likely not matching the vehicle at all and many other options don't apply. Get accurate coding for the vehicle in that case.
