Hi! Xentry PassThru and FullFix - anyone can help? Please! Thanks!
No luck in finding any with solution.
Nothing works with me
dit you guys find sometehing to solve this Issue? I try to add a VAS6154A (VAG) to my Xentry XPAD2 Fullfix
what i have done so far:
I tried over 10 hours to get my vas6154A to get work with
DTS Monaco, mostly cause of the Wireless function.
Simply installing ODIS with the driver is not enough because DTS Monaco can't use the D PDU API of Volkswagen
(ERR: Interface not supported)
You need the PassThru Software espicially for the device, but the Volkswagen PassThru Software is nearly unfindable.
The VAS6154A shares the same hardware as the I+ME ACTIA TC XS, but cause of another Hardware ID
you can't use the TC XS drivers for the VAS6154A and even playing with replacing, and configuring
different files (in the driver and the D PDU API Installation), installing the driver without driver signature enforcement,
trying to flash the TC XS firmware - it won't work.
Preparements:
After searching a long time in the internet, i found an link to an old ODIS Version where the distributor included the
Volkswagen D PDU API. Because i lost the link over the night, i reuploaded it for you:
Installation:
1. Install ODIS (i installed 9.1.0, select VAS6154A if the setup asks) which installs automtically VAS6154A D PDU API and Drivers
2. Ensure your VAS6154A is reachable from the computer, for the beginning you should use USB Connection
3. Install downloaded PassThru Driver
4. Run VAS6154 Configuration Tool and enter your Serial Number (you can get it from the web configuration page of the VAS6154A)
5. Run DTS Monaco, open "Manage DTS Projecs", open tab "System settings", right click on "Interfaces" and select "Add Interface"
6. Select D PDU API Device and freely select the name for the interface, click next.
7. Use the following options:
D-PDU-API: Softing AG EDIC_D_PDU_API_??_??_???
Module type: J2534
Vendor module name: VendorName='I+ME Actia GmbH' ModuleName='VAS6154 PassThru' [...]
Cable: J1962_CARB
8. On the next page, use the follwing settings:
ISO_11898_2_DWCAN (6 HI, 14 LOW): CAN 1
ISO_9141_2_UART (7K, 15L): KLINE 7
other leave blank (: ---)
9. Finish
You should now be able to open a projekt with the VAS6154A (visible as your freely selected name for the device) and it will connect
to your VAS6154A automatically. While connecting, a little popup opens in the bottom right or an dongle icon in the icon area of the taskbar
will be shown.
In Access Point mode, the VAS6154A should be recognized during connected Wireless lan automatically.
In Instrafructure mode, it may be possible, that the VAS6154A is not recgnozied. In this case, add the IP and Hostname
of the VAS6154A in the following file:
C:\ProgramData\Volkswagen\VAS6154 Driver\VAS6154-Static-Devices.ini
You can now also configure BMW ISTA for using the VAS6154A:
Open PassThruD Configuration and select the VAS6154A, enable 115k communication and save. IMPORTANT: You must open
the tool with administrator privileges. The go to C:\EDIABAS\BIN\EDIABAS.INI and change INTERFACE to STDTongueassThruD.
After this, reboot the computer, open ISTA and select in settings of ISTA to use ediabas.ini (NOT PassThruDevice!).
After that i wrote a .bat file to change the Registry key to Start as PassTrough ... so far so
if i start xentry now following Dropdown is shown:
Attachment 1035011
from now on my DAS dit not Start anymore ....
maybe we can work on this together.....
Erklaernix
Hello netifa,
thanks for sharing the link but unfortunately I'm not registered on this forum and they want 30 bucks from new members....
erklaernix
OK i see.... what a fool
Thanks for the info
