    Jul 2022
    Default Esp long coding for GOLF 5 mk60ec1
    I'm writing this post for my golf 5 with and esp/abs problem. When i got this car everything worked fine except one dashbord light that i forgot about, i got it to the mecanic where he did something in vcds and after that my abs/esp stopped working. I think it has to do with the long coding. I tried doing it myself but failed, it says that coding is out of range everytime. I even bought a calculator for esp, i will attached if someone needs it. So I will post my vcds scan and my hardward info. If someone can help me diag this problem.
    your problem is not codind...
    you need to perform basic setings and System Function Test
    rafal's Avatar
    UK - PL
    looks funny when users buying tools and don't know how to use
    need help
    now my goal is to buy xp-005
    who will help?
    Jul 2022
    I did the system function test, it worked, but when i did the basic setting i got No Valv [000/000] >000< Error 212
    Jul 2022
    I've finished all the test, everything work after i clear codes, but after 20km/h abs esp light up and parking brake flashed and i get 1130 abs operation implausible signal
    01130 - ABS Operation
    01130 - ABS Operation: Implausible Signal
    Possible Causes
    Fuse(s) faulty
    Modifications/Retrofits incompatible
    Wiring from/to Brake Electronics Control Module (J104) faulty
    Electrical Interference from External Sources
    High Frequency Radiation (e.g. non-insulated Ignition Cable)
    Possible Solutions
    Check Fuse(s)
    Check Vehicle for Modifications/Retrofits
    Temporarily remove Modifications/Retrofits (including Wiring)
    Check Wiring from/to Brake Electronics Control Module (J104)
    Check Brake Electronics Control Module (J104)
    Special Notes
    This Fault Code can only be cleared after performing a Test Drive above 20 km/h (13 mph)
