Results 1 to 7 of 7
    Sep 2021
    Default ecu bench tool and need help please
    Hello.
    I have an Ecu Bench Tool.
    It is bought from Aliexp... and they sent the wrong cable.
    The plugs are the same and it's not good. I can't use the device.
    I bought a good plug to connect the wires in the plug, but I need a diagram after an original cable for this Ecu Bench Tool. easily make a diagram after the original cable with a measuring device.
    001.jpg002.jpg004.jpg005.jpg435688698_1163883981315802_6735263397638616086_n.jpg.
    srzar's Avatar
    Jun 2013
    hello
    not the first came from aliexpress with wong wires
    you need that pinout
    2 - K Line
    3 - Can H
    4 - GND
    6 - S2 = GPT1
    7 - S1 = GPT0
    9 - +12v
    10 - Can L
    i hope you dont have problems
  3. The Following 3 Users Say Thank You to srzar For This Useful Post:
    danielif (29th April, 2024), Sammyr Rafa (29th April, 2024)
    Sep 2021
    Attachment 1024236
    Bro, is all cable like this? Are all threads like this? Please help me. I want to put all the wires in their place so that I don't have problems. I'm a beginner and I don't want to have problems with these threads. And one more question, is the trunk wire in the diagram white or gray? 8 or 10?
    srzar's Avatar
    Jun 2013
    You dont need boot cnf rst cause not used with any protokol
  6. The Following 2 Users Say Thank You to srzar For This Useful Post:
    Sep 2021
    Ok Bro, thank you very much for your help.
    In this situation, I don't need boot?
    I repeat that I am a beginner and I don't know that well.
    That's why I ask so many questions.
    I hope I don't disturb you with my questions.
  8. #6
    srzar's Avatar
    Jun 2013
    that tool not read on boot mode use bench mode with no open ecu, that pinout not is for that device you need pinot with egpt like pcmflash pinouts at pcmflash.ru/downloads module 71 for edc17, module 77 for edc16..... or see help files inside amt bst installation folder
  9. The Following User Says Thank You to srzar For This Useful Post:
    Sammyr Rafa (30th April, 2024)
  10. #7
    Sep 2021
