Results 1 to 15 of 16
    rob h's Avatar
    May 2011
    Default ignition core Hu101 2014+ removal
    Hello guys,
    I have been given a ignition lock, 2014-2016. Ford transit.
    The key, is a bit worn, and wont turn much.
    Only halve way, from 0 to position 1.
    Also with a new cut blade, and picked with a lishi. same result.
    They removed the complete lock, removing the bolds.
    Did that set of something, now blocking the core from turning?
    Dec 2021
    Quote Originally Posted by rob h View Post
    Hello guys,
    A bit hard to understand… did you replace the wafers to new ones in the right order ? Are you using the new blade ? All the wafers evenly surfaced on the barrel?Common issues with those wafers getting warned .. rarely the back switch on those fails ..
    rob h's Avatar
    May 2011
    I have not taken the lock appart.
    Only removed the elctic switch.
    The ign lock (aluminium case,with switch at one end, and ign lock at the other side), is bolted, with 2 bolts. To the steering colllum,rack.
    These 2 bolts, are hard to remove. And i guess they might have hold someting inplace. inside the lock core.
    I have been given this lock, to make a new blade.
    And if needed, take it appart.
    But the core,, wint turn much.
    from 0, to postion 1, it only comes halve way. But does fully pull down the steering locking bar.
    And they bought another lock, to replace it, if needed. Doing exactly the same.
    Also limited to turn, not reaching lock position 1 either.
    Dec 2021
    Have you checked if the electric back switch is turning gently with a flat screw driver?
    Dec 2021
    Quote Originally Posted by azikri locks View Post
    If you took the electric switch out and still same thing take the barrel out and see if it turning fully
    rob h's Avatar
    May 2011
    Barrel release, needs to be in position 1.
    It does not turn that far.
    The electrical part, is not the problem.
    I removed that part, first think i did.
    To have 2 identical locks, removed the same way, with the exact same problem.
    Must me a factory build in spring loaded, contrapment like vw ign locks.
    P&D's Avatar
    The new key
    Did you read the cuts on the key by eye or decode the cuts on a cutting machine ?
    Dec 2021
    I know in fiesta ignition when you turn the key in the ignition without the back switch electric part the key will remain stuck in the first position until you put the electric switch back switch back into the ignition… make sure you don’t have a button we’re the back switch goes … the key turning freely in the barrel when the barrel is out of the ignition?
    rob h's Avatar
    May 2011
    IMG_20240430_204646136.jpgI always decoder Ford by eye
    The key, is not the problem.
    They wanted to switch a full immo kit.
    Until i told them, they needed the abs unit asswel.
    So i cloned the ecu, and the car starts.
    They already removed, a good working ignition lock, by taking the 2 bolts out.
    Instead of simply swapping the ign barrel.
    So, know i have been given the 2 identical failing to turn up to pos 1. So no barrel release is possible.
    I cannot be the first to stumble on to this.
    So, i need to find a solution, with having to cut 2 locks open.
    1 needs to become functionel.
    Dec 2021
    So the key turning in the barrel when it’s out of the ignition? If yes so something is going on with the steering lock mechanism bit strange though usually there is no issue beside of the barrel itself…
    rob h's Avatar
    May 2011
    The turn the ign, without switch,
    Yes, it must be something like that.
    Dec 2021
    Rarely those steering locks failing… strip it.. I can’t see other options
  13. #13
    rob h's Avatar
    May 2011
    I managed to remove the barrel.
    I aplied a lot of force, to turn the key, beyond the tough spot.
    It remained turning tough, but atleast, i have gotten the barrel out.
    The barrel, it is working perfect.
    After re placing it, back in the housing, and turning it all the way up to the start position.
    After atleast a 100 turns, it is getting a bit better.
    Still the lock, wont turn itself, by spring out of the crank position.
    Stranges locks. I need to figure this out.
    And take the spare apart soon.
  14. #14
    Dec 2021
    Check the wafers bro sound like bad wafers if you don’t have replacement ones file them a little bit but make sure off them are perfectly evened surfaces
  15. #15
    rob h's Avatar
    May 2011
    you try to help, put if you read the posts.
    The core it fine, the key turn perfect, in the barrel core, when it is removed.
    Only after putting it back in the aluminum steering lock casing , it turns heavy.
