    super jumbe's Avatar
    Livingstone
    Default SMART PRO CABLE IVECO DAILY 38 PIN ANY HELP.
    Lads need advice, I have got Iveco Daily 2005 to add key the issue is this old van has 38 round pin OBD plug, I tried with the plug I had 38 pin to female OBD2 diagnostic cable but my smart pro will not connect, the van connects with any fault code reader, do I need to buy cable from Advance diagnostic firm, any advice will be appreciated.
    Livingstone
    Thia cable not cheap ADC146 Iveco Cable.
    EU
    no you can use any that have correct pinout
    27 pin +
    30 gnd
    12 immo
    I made my with only 3 wires going from OBD
    but cloning is faster and don't need PIN
  4. The Following 2 Users Say Thank You to davorOS For This Useful Post:
    super jumbe (5th May, 2024), wuza (4th May, 2024)
    Livingstone
    Thanks for pinout but how can you clone chip on a all keys lost car? rummors with immo box out you can add key in dump if you have C3 clonning chip.
    Jul 2019
    Melbourne, Australia
    Quote Originally Posted by super jumbe View Post
    Immo box out you can both write in a PCF7936 with tango or use a cloning chip to emulate an existing key. Immo box bolted to the top of steering column near where the column meets the floor. 1 bolt is easy, the other a bit hard. Memory device is separate SOIC8 eeprom 93C46 from memory.
    EU
    yes.correct I also make them by dump with Tango if AKL
    hard to remove immo box but often needed as PIN card not availible so You need dump anyway.
