Results 1 to 2 of 2
Thread: hello
    May 2024
    Red face hello
    hello everyone.
    just getting into ECU with Forscan/ELMconfig...
    my Ford Kuga 2.0 TDCi Manual6 AWD 136PS has some issue with Turbo Vane controll - vacum valve is still enabled which gives too much pressure.
    Car drives ok in the city, however it takes time to overtake a trailer as there is no power.
    I have tested EGR actuator with Forscan and i can control and verify it works. I cannot control Vaccum valve in Forscan - not sure it is ok or not as I have not tried it before on a working car.
    I suspect ECU has disabled DPF - any way to verify that?
    I need to research if there is possibility to make full backup of PCM Sid206 and try uploading different version - 8V41CC instead of 8V41CB.
    kind regards to everyone!
    May 2024
    Simf
    hello everyone
