Results 1 to 4 of 4
    Nov 2012
    Default PSA DCM7.1A Foxflash!
    Please, I would like to read an PSA DCM7.1A ECU, but before starting, I want to verify with you which one of the connections is correct and safe!
    Because, I read that someone damaged this ECU when he use the connection that shown in Foxflash manual ''Image 01''. Is this true?
    In Foxflash manual is showed (Boot with yellow wire and cnf1 with pink wire)?!!! Image 01, or (connect the grey wire with Boot pin and CNF1)? Image 02
    THANKS ADVANCE!
    Nov 2012
    No one has ever dealt with this before?!
    mau111's Avatar
    Aug 2014
    it's not about the color. it's in the name
    this is the same connection
    tinchocbr's Avatar
    In my house
    Quote Originally Posted by khaleddaddi View Post
    Look this
    http://blog.obdii365.com/2022/11/15/...m7-1b-in-boot/
  5. The Following User Says Thank You to tinchocbr For This Useful Post:
    khaleddaddi (1st June, 2024)
