Results 1 to 7 of 7
    Apr 2021
    Default kia picanto all key lost 2004
    hi guys
    i have a kia picanto akl
    key code was oke
    pin code was wrong
    is there any other way to get the right pincode?
    Dec 2010
    Nottingham
    what was vin and what was pin code you tried
    No one can help you without the vin number and without knowing what pin you tried
    on 2004 model the pin code is normally the old pin code derived from the last 6 digits of the vin number , some dealers used to change this to last 6 digits of vin , but most will be derived from last 6 digits of the vin
    Apr 2021
    Quote Originally Posted by rapidlocksmiths View Post
    Hi thanks for the fast reply,
    the vin number was: kneba24324t014099
    the pin code that i get: 556928
    Oct 2015
    Long time ago i had problem with old kia car where the latest 6 chasis numbers starting withn 0.
    All the time i got wrong pin code. If i remember well i change tham in 1 so your pin code can be 822976
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
    Dec 2010
    Nottingham
    all pin calculators will give you that pin , you can try rokibar sugestion above , you can try last 6 digits of vin and same reversed
    if someone has changed pin then could be anything , even seen 123456 .
    Apr 2021
    Yes, the customer just told me that the engine has been replaced over the years. So i guess the ECU is also replaced.
    Is there any change to get it direct from the ecu?
    ecu part number is:
    KEFICO
    9 030 930 494F A2
    SAH4IS12
    Dec 2010
    Nottingham
    you should be able to get it from the 95C160 chip in this , zedfull lists it
