    Aug 2023
    Default Need immo off on pcr2.1 ecu please
    Have a donor ECU vw pcr 2.1 not able to do direct clone so would like an IMMO off on the donor unit if possible.
    I have added both the internal flash and the eeprom reads from the donor unit.
    Any help would be much appreciated, thanks in advance
    Aug 2023
    No solution for this?
    Dec 2018
    Hi of course there is a solution for immo off. Did you write that you have read eeprom and flash from Doner ECU? But what do you want to do with it? You cannot upload this file to a new ECU. If you have the same new ECU, you can count the data transfer to the new ECU. Best regards
    Aug 2023
    Hi no the pcr2.1 is a locked eeprom so It won't allow me to do a straight clone so I want to do an immo off on the donor ecu so they can use that one to get the car running
    Aug 2023
    Can anyone help with this? thanks in advance
    Sep 2020
    Romania
    Hello yes i can do it but will not be for free so if you interested contact me
