    richard27's Avatar
    Aug 2011
    Default ford focus 2020 id 49
    hello one ford focus add key 2020 succesfull
    Now the car is running but I cannot turn off the tire pressure sensor, the screen keeps warning.
    I tried to clear the error with another Ford device, but it doesn't work. Why do you think this error might occur or how can I turn it off?
    There is a dashed line with a car sign on the screen
    ​information sharing
    Jul 2019
    Quote Originally Posted by richard27 View Post
    It was a relatively common fault on a few programmers where they corrupted the BCM flash data while preforming key programming on newer Fords. The symptoms showed as a TPMS fault that was impossible to erase. As far as I know the fix back then was a new BCM. Sometimes Ford accepted the repair under warranty as well when the cars were newer if one played their cards right.
    Don't know if a newer fix was discovered as most programmers fixed the issues with their software.
    I am sorry but I am not too familiar with the problem as I have never encountered it.
    If you write that tool you used someone might be able to shine a little more light on your issue.
  3. The Following User Says Thank You to askkey For This Useful Post:
    richard27 (13th May, 2024)
    Dec 2010
    Nottingham
    What tool did you use ?
    as said above this was an issue some tools had , halkyard tech ht3 and truecode had this issue , theres some long threads on it on this forum if you search, truecode fixed the issue on their software .
    as stated the fix was a new bcm , you will most likely find that the battery will also go flat over 24 to 36 hours of not being used .
    what fault codes do you have
  5. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  6. #4
    richard27's Avatar
    Aug 2011
    hello There is no error code in the car, there is only a warning on the screen, the device I use is Zedfull.
    I have done this before and there was no problem with this vehicle. We tried it with the original service device, but we still failed, I think the tpms codes were deleted.
    Are you 100% sure there isnt a U3000 error stored in the BCM ? Providing there isnt an an actual hardware fault with the BCM, its possible to clear U3000 errors on the bench.
  8. The Following User Says Thank You to MrSporty For This Useful Post:
    richard27 (17th May, 2024)
  9. #6
    richard27's Avatar
    Aug 2011
    I sent the car and it went away. If it comes back, I can continue the topic from here, thank you.
