Results 1 to 14 of 14
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default KEYDIY FIAT GP DELPHI BSI KEY PROGRAMMING PROBLEM
    Hi.....
    i try to add a key from keydiy (NB11 series with 3 buttons) to a Fiat GP and delphi bsi.....
    i prepare the key with keydiy SW, i have HITAG2 id46 7946 transponder produced for the Fiat, i have the pin code from the bsi....
    after i try to add in bsi with pincode, but not possible.... key authedication error, i try with MES.....
    the eeprom from bsi must prepared first with this key to accept the programming????
    Η κότα έκανε το αυγό ή το αυγό την κοτα;
    Jan 2018
    need to prepare dealer key but dont use kd or xhorse they tend to have problems
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by bmujka View Post
    dealers key in a Fiat??? first time i hear that.....
    Jan 2018
    f.jpgcheck obdstar dealer key
    May 2020
    Newest obdstar updates have a problem, they read pin code and prepare dealer key fine, but when you're adapting keys to car, it will for some reason fail (as if you entered a wrong pin). Pick up any other tool, for example autel, write the same pin and it will add it fine.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    i don't have obdstar, i use keydiy NB11 key and repaired with keydiy kd-x2...............
    and i use multiecuscan for adaption..... pin is accepted but the key not........
    Dec 2021
    Quote Originally Posted by Panathaole View Post
    Wiche fiat is that? Model and year? As mentioned above you need to read key data and prepare dealer key first ..all by OBD. Need to generate transponder preceded for fiat with xt27 or any other 46 (depends on the model)fiat pre coded, you can use keydiy or xhorse the remote might fail to lock &unlock but never fail to start the engine
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    car is a GP 2007 with delphi bsi.... i choose in keydiy grande punto(06-10) Delphi BSI (R01931) and try to add it with MES.....
    Dec 2021
    Try this.. first program the original key then the keydiy key and report
    Dec 2022
    maybe first time make fiats, only punto 2000-2003 and first doblo no need dealer key
    first dealer key then learn key, car starts and button works
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Is true that I don't make keys.....(only few cloning and few for older cars....)
    Then I guess I need other tool for this work.....
    I am planning to buy im508s...... probably it will be easy job for it....
    Dec 2021
    You should’ve mentioned this at first… you need a tool that is able to generate dealer key not only programming
  13. #13
    Dec 2022
    yes im508 works great for all fiat group, easy job on 5 minutes
  14. #14
    tepSIJA's Avatar
    Dec 2015
    OTP
    autel im508/608 , 5min job, read immo data & Pin, make dealer key, learn keys.
    U must have tool to precode/make dealer key. Multiecuscan can only learn dealer keys.
    hints
    1.First learn original key after that your new key
    2.Dont use KD/Xhorse for fiat, 50/50 succes/fail from my experience
    3.Buy aftermarket key for that type of car, cheap and good, 10-15Eur online
    Tempus Omnia Revelat
