Results 1 to 11 of 11
    rob h's Avatar
    May 2011
    Default W906 MB sprinter EIS stolen
    Hello guys,
    This car did only have oem keys,(no aftermarket) so no password reading from these.
    I needed the password, to restore the immodata in a replacement EIS. And to use the oem keys.
    And to unlock the ELV.
    I completed the job, using a made up password, elv emulator and 2 new keys.
    Is there a way, to collect the ori password, from the ELV dump?
    Quote Originally Posted by rob h View Post
    Hello guys,
    NO, not possible!
    by this type only new keys.
  3. The Following User Says Thank You to vageric For This Useful Post:
    rob h (14th May, 2024)
    Dec 2012
    EU
    How did you solve the engine ecu ??
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by gttuning View Post
    ECU will accept aftermarket keys if is done right, same as you add a extra key
    Jul 2019
    Melbourne, Australia
    Hello guys,
    From my experience in your situation you must either get a dealer EIS & workshop key OR get a second hand EIS with keys or make keys for it on the bench and while doing so reset odometer in EZS, then erase ECU & ELV, then write SSID from donor EZS to cluster. Then program ECU & ELV for donor EZS. Will require new keys of course.
    Unless one of your OEM keys is a NEC/Motorola(can't remember the pin count) dual in line package you cannot recover the password with any known tool.
  7. The Following User Says Thank You to Spiritech For This Useful Post:
    wuza (18th May, 2024)
  8. #6
    You can read the ecu data and generate eis data.
    Wipe the donor eis data
    Read the ssid from the key
    Load the generated eis data, set ssid to same as original key ssid and check vin, change password to whatever you want, then write data to donor eis.
    Then generate key files and make new key.
  9. The Following 2 Users Say Thank You to u.s For This Useful Post:
    lion0304 (14th May, 2024), wuza (18th May, 2024)
  10. #7
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by u.s View Post
    This seem process with CGDi if my memory is good
  11. The Following User Says Thank You to lion0304 For This Useful Post:
    u.s (14th May, 2024)
  12. #8
    yes mate, it is
  13. #9
    is same as all devices! not only CGDI
  14. #10
    rob h's Avatar
    May 2011
    i read the ssid from the existing keys.
    I used mb cgdi, i prefer it to the Xhorse tab.
    You can convert the data read from ecu, and also from the tcu, to created a eis file.
    This function is present, in both ecu and tcu menu. Atleast in cgdi, and probable also in other mb tools.
    Cgdi does have a elv programmer, that covers W204 and W906.
    I wondered if that would recover the pass. So i guess, it can not.
    Maybe one day, a tool can do this.
  15. #11
    ricked's Avatar
    Apr 2016
    Europe
    vvdimb does not support importing ecu data to eis or visa versa, i did try it but not supported
  16. The Following User Says Thank You to ricked For This Useful Post:
    rob h (17th May, 2024)
