I recently corrected mileage on a 2005 Chevy Colorado. The original eeprom on the cluster went out so I replaced it with a virgin eeprom. I loaded a 93c56 bin from a previous '05 Colorado I had done and zeroed it out. I had corrected the miles on the BCM (95040 eeprom), and then put everything back in. Instead of showing miles, it now shows kilometers. The original miles were 242704 and I had corrected them to 165212 miles. It shows the mileage I adjusted but in KM. I'm not sure if it's because I used a bin file from a different Colorado for the cluster or if something was done in the BCM but I've done many of these vehicles and this is the first time this has happened. I'm uploading the bin file for the cluster (93c56) and the adjusted bin file for the BCM (95040) to see if someone can help me correct this from KM to Miles.
