8J0907115B 0261S02085 386828 '08 TT TFSI 200HP DQ250Stage 1 w/ P2181 off please
Post file
Envoyé de mon RMX3741 en utilisant Tapatalk
why P2181 off? why? your problem need to be fixed
18613/P2181/008577
Jump to:navigation, search
Contents
18613/P2181/008577 - Performance Malfunction in Cooling System
Possible Symptoms
- Malfunction Indicator Light (MIL) ON
- Reduced Heater Output - Cold toes
- Incorrect Temperature Gauge Readings
- Increased Emissions
Possible Causes
- Faulty Coolant Sensor
- Faulty Coolant Thermostat
- Faulty Wiring, Connections
Note: This fault code sets when engine coolant temperature mapping is lower and out of expected range based on operating conditions of the engine.
- For example: Engine warms up, thermostat opens and stays open, coolant temperature drops below normal operating range. The ECM knows the coolant temperature should stay within 80.0...110.0 °C typically after warm up. Thus a drop in coolant temperature below normal operating temperature is not possible without a Malfunction in Cooling System.
Possible Solutions
- Check G62 - Engine Coolant Temperature Sender
- Inspect wiring for G62 (Coolant Migration, damage, corrosion, etc)
- Check (if applicable) G83 - Radiator Outlet, Coolant Temperature Sender
- Inspect wiring for G83 (Coolant Migration, damage, corrosion, etc)
- Check Coolant Thermostat
- Use Graph function in VCDS, Measuring Value Blocks - MVB
- Start Engine cold, graph Coolant Temperature Sender (G62) Typically MVB Group-001
- Hold RPM around 1,500rpm and watch coolant temp increase in Graph until thermostat opens, indicated by a slight drop in coolant temp
- If coolant temp drops below minimum operating temperature (80°C) or never reaches operating temperature, (verified by external thermometer) suspect failed thermostat
- Vehicles with both G62-Engine Outlet, Coolant Temperature Sensor and G83-Radiator Outlet, Coolant Temperature Sensor
- Use Measuring Value Block group MVB-130 instead on MVB-001
- G62 should increase in Temperature before G83 increase when engine coolant is cold
- G83 will increase when the thermostat opens and after G62 reaches operating temperature (80°C)
- If G62 and G83 both increase while engine warms up, suspect failed thermostat
Special Notes
- Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
- Freeze Frame data stored at -40*C is generally an indication of a faulty ECT or wiring.
- Freeze Frame data stored at +140*C is generally an indication of a faulty ECT or wiring.
- Freeze Frame data stored with in the 68*C ~ 80*C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
if u didnt fix it here it is
no personal info in sigs !!!
wrx757 (28th May, 2024)
