hello
after km correction the digital odometer wont go on again , i try to put the original data back and still the same
anyhelp please if have some ori data or solution
kode ; YA129-001
year ; 2023
thank and rep
hello
kode ; YA129-001
year ; 2023
thank and rep
if i help don't forget THANKS AND REPUTATION button
Could be an idea to post the files.
If i helped you with your problem, please press the Thanks button.
Ask your questions in the forum, no response on private messages.
Bens (14th May, 2024)
I th
I think this reading is corrupt, because you can't find it, I read it with IProg Pro on the circuit but it can't write even when opened. With CG it can read and writenow the IC is deadink this reading is corrupt, because you can't find it, I read it with IProg Pro on the circuit but it can't write even when opened. With CG it can read and writenow the IC is dead
km ; okok
I think this reading is corrupt, because you can't find it, I read it with IProg Pro on the circuit but it can't write even when opened. With CG it can read and writenow the IC is deadI think this reading is corrupt, because yookasajdasasbu can't find it, I read it with IProg Pro on the circuit but it can't write even when opened. With CG it can read and writenow the IC is dead
Your data looks okay. Check soldering.
