Results 1 to 5 of 5
    vialli's Avatar
    Aug 2018
    Romania
    Default Pincode from HFM Clio 4 dump
    I have this d-flash from a Clio 4 HFM and I need the Pincode to program another donor HFM
    I know RET can provide Pincode from HFM dump, I don't have RET so I need someone here on DK who has this programmer to send me the Pin
    Much gratitude
    Feb 2009
    hello.
    try this
    ISK : EA DD D4 4C FC D2 4E 29 59 B6 66 EF C0 67 12 F7
    PINCODE: 4F E5 68 A6 3A 6A 8D DD 58 4A AE 25 6D 40 00 20
  3. The Following User Says Thank You to gogu For This Useful Post:
    vialli (15th May, 2024)
    Aug 2015
    Spain
    Quote Originally Posted by gogu View Post
    hola.
    prueba este
    ISK: EA DD D4 4C FC D2 4E 29 59 B6 66 EF C0 67 12 F7
    CÓDIGO PIN: 4F E5 68 A6 3A 6A 8D DD 58 4A AE 25 6D 40 00 20
    In RET it shows the same code. Itīs OK
  5. The Following User Says Thank You to Josue For This Useful Post:
  6. #4
    vialli's Avatar
    Aug 2018
    Romania
    hello.
    try this
    Thank you friends, the Pincode is correct and I programmed the donor HFM, everything is as it should be
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by Josue View Post
    Yes, it is corect
    Thank you for help
