Results 1 to 12 of 12
    Aug 2015
    Default VW EDC17C64 Start/Stop off
    Hello everybody,
    who have tested solution for this ecu SS off ?
    Tested 2 solution with no success.
    Don't forget to press THANKS & +REP buttons
    Sep 2015
    Quote Originally Posted by shooperis View Post
    Hello everybody,
    hello try and comment
  3. The Following User Says Thank You to amlop For This Useful Post:
    shooperis (16th May, 2024)
    Aug 2015
    Quote Originally Posted by amlop View Post
    Hello, thank you. I tried this solution, it doesn't work.
    DamosTuning's Avatar
    Apr 2024
    What do you mean with SS off? Some of solutions just reverse the sequence so instead of on standard it stays on off.
    I think you can also adjust this with VCDS if im correct.
    Aug 2015
    Quote Originally Posted by DamosTuning View Post
    i mean dissable Start/Stop system. For this car is not possible to do reverse the sequence, also for this car is not possible to adjust temperature or voltage adaptations ralated to Start/Stop functionality.
    mainhattanracin's Avatar
    Oct 2020
    Kosovo/Albania
    here mate start stop off give thanks and rep 4 pass
    Dec 2019
    UK
    Try this........
  9. The Following User Says Thank You to peechie For This Useful Post:
  10. #8
    Aug 2015
    Quote Originally Posted by peechie View Post
    Try this........
    Hello, thank you. It is same solution like "amlop" , it doesn't work.
  11. #9
    Aug 2015
    Problem solved.
  12. #10
    Dec 2014
    PL
    Problem solved.
    You started a thread with your problem, but even though others tried to help you, you did not share information on how you solved the problem.
    Unless you paid a lot of money for the solution.
  13. #11
    Dec 2014
    PL
    xxxxxxxxxxxxxxxx
  14. #12
    Aug 2015
    Quote Originally Posted by Mario6 View Post
    Start-stop turned off in flash with proper solution.
  15. The Following User Says Thank You to shooperis For This Useful Post:
    Mario6 (15th June, 2024)
