Hello colleagues, I have starting problems with this car I would like to immo off here I attach data
suzuki vitara 2.0 hdi year 2004
ecu: sid301A 5WS40160B SIEMENS
EEPROM :93C56
this car has a keyboard
EEPROM :93C56
-------------------- SID801A ------------------------
need help
now my goal is to buy xp-005
who will help?
garagesport (18th May, 2024)
yes friend it is a sid 810A
Can someone help me with a tested immo off, thanks and regards
need help
who will help?
garagesport (22nd May, 2024), sadard (28th May, 2024)
I also have a 5ws40160b-t from a Vitara 2.0HDI. It has a keypad.
The ECU has a single green PCB and the epprom (ST 93c56 w3) is located in the same side as the large caps and coils.
I have researched in the forum and in the past other coleages have asked for the flash dump for disabling the immo. I will receive a ktag clone by the end of the week if the flash dump is needed.
Can you help me rafal? Recovering the code would be preferable over doing an immo off but either solution would be great.
I have attached the epprom dump in 8bit and 16bit.
EDIT: I didn't find anything specific for this ecu, so I compare it with a 5ws40160a-t and adjusted a little bit. I don't know if it will work 100% but the immo is 100% disabled, this Vitara is starting again after 10 years under a tree.
I attach my immo off file, no password. I used 16bit mode.
Please give thanks if useful or advice on how to improve it.
