Results 1 to 3 of 3
    rtvservis's Avatar
    Sep 2009
    Default HELP VITH REPAIR SOLUTION FOR MINI MEVD 17.2.2 140401 Misfiring cylinder 4 detected
    Product category:
    Engine Control Unit
    Manufacturer number:
    0261S06659
    Brand:
    Bosch
    Manufacturer:
    BMW (Mini)
    Vehicle manufacturer no.:
    7 620 985, 7620985
    HARDVARE OR SOFTWARE PROBLEM .
    SCHEMATICS ENTNYG
    THENXX
    https://www.bosch-repair-service.com/en/engine-control-unit/bosch/mevd17-2-2-0261s06659001/
    Productdetails - Bosch
    Sep 2021
    Check the cable connected to Cylinder No 4. Is there continuity in the ECU? If the cables are intact, follow the relevant pin. Check the resistance between the mosfet and the gate source.
  3. The Following User Says Thank You to ryzen For This Useful Post:
    rtvservis (17th May, 2024)
    Sep 2013
    garage
    i do one ecu with a ngd8201ag burn ....may not be your case ...
  5. The Following User Says Thank You to Mr BLACK For This Useful Post:
