Results 1 to 3 of 3
    Fec001's Avatar
    Default Avensis 89170-05080
    Hi!
    I have a unit here with DTC B1100. I found on forum someone solved this DTC by exchange eprom because that cause this fault code.
    Before I exchange eeprom can someone check if the dump is 100% ok please?
    Apr 2024
    Беларусь
    Your file has been cleared. Check it out. Click "Gratitude"+ "reputation".
    Fec001's Avatar
    This file, not working .
    Solved by other member, thanks for efforts!
    EDIT:
    Not solved, still have B1100 DTC. I will try to exchange eeprom
