Results 1 to 9 of 9
    May 2017
    Default Opel Astra J A13DTE Dpf Problem
    Hi to all!
    I have a problem with Opel Astra J.After dpf delete car works fine no smoke no dtc's but after few kilometers i have message ''diesel partic filter is full continue driving mandatory'' in dashboard.When i reset dpf message disappears for a while and reappear.Have anyone meet and fix this problem?
    Ecu is edc17c59 and i've done manual dpf off and reset dpf before write mod file.
    Jul 2012
    you have not attached the files to understand if the problem is your incorrect work or you need to disconnect the differential pressure sensor continue reading
    capkin92's Avatar
    Jun 2018
    Quote Originally Posted by georgedigital View Post
    Hi to all!
    I can make a mod for you without any problems
    Flex MASTER WinOLS 4 , FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess
    May 2017
    Here ori and mod files
    Oct 2015
    Portugal
    I can do a file for you too but your problem is not the file bro
    Probably your file is good, you need recode car (OPCOM) to dpf disable in cluster and motor ecu.
    I hope i help you with this answer.
    Cheers
    Nothing is impossible if everyone helps.
    Together we can do amazing things.
    May 2017
    I have try with opcom and gds2.Only dpf reset in ecu.Cluster have not this function.
    Aug 2022
    Spain
    46696c65207365727669636573
    DPF / OPF / EGR / SCR /…..
  8. The Following 2 Users Say Thank You to farawhy1 For This Useful Post:
    biggggi (27th May, 2024), georgedigital (22nd May, 2024)
    May 2017
    Quote Originally Posted by farawhy1 View Post
    farawhy1 so far your file work good!!!
    Thank U!
  10. #9
    Mar 2013
    Greece
    hello mate! may i have pass for the file? i have the same problem... thanks in advace!
