Results 1 to 10 of 10
    May 2024
    Default EDC16c34 immo off
    I would like to know how to remove the immobiliser on ECU:
    1.6 EDC16C34 ECU 0 281 013 872 96 648 437 80
    I have read the st 95160 eeprom and attached it for guidance or change.
    Many thanks.
    No mileage stored on these I hope!
    I have read using eeprom programmer ch341a by clipping on chip attqached to board.
    Is it possible to write the same way or does the eeprom need to be removed.
    I also have program from here https://www.digital-kaos.co.uk/forums/showthread.php?t=288010
    Last edited by one pound; 17th May, 2024 at 07:25 PM. Reason: additional methods seeked and clarification of stupidy
    aboelgood's Avatar
    Feb 2023
    Egypt
    Quote Originally Posted by one pound View Post
    Many thanks.
    Nothing For Free I See That From All ...
    I will give the file for free for whatever I want ...
    May 2024
    Quote Originally Posted by aboelgood View Post
    Many thanks, I have a ch341a programmer I clipped it to the 95160 on the board to read. Can I program it with the 95160 on the board or do I have to remove it?
    aboelgood's Avatar
    Feb 2023
    Egypt
    The same way you read the file, write the file, lock it, and try the car , Thanks And Rep For Pass File
    May 2024
    okay what is the password for the zip...
    aboelgood's Avatar
    Feb 2023
    Egypt
    Look at my good words
    May 2024
    oh I see the * adds reputation, sorry I'm new did not notice that.
    Well if you look at my post I have the program to do that what I was asking was whether it can be programmed without removing the eeprom using ch341a.
    now it seems the write pin is tied to + so not sure if that will work on the other hand the data sheet says it is driven low to write so that seems to suggest it should. Others show (youtube) the chip needing to be removed.
    Off course I can try your file on my car but I think it is only right that you thank me and add to my reputation for doing this too
    aboelgood's Avatar
    Feb 2023
    Egypt
    now it seems the write pin is tied to + so not sure if that will work.
    You Need Me Thanks You For What ??
    May 2024
    richard27's Avatar
    Aug 2011
    Quote Originally Posted by bir pound View Post
    ECU'daki immobilizatörün nasıl çıkarılacağını bilmek istiyorum:
    St 95160 eepromunu okudum ve rehberlik veya değişiklik için ekledim.
    Çok teşekkürler.
    Umarım bunlarda kilometre kayıtlı değildir!
    Eeprom programlayıcı ch341a'yı kullanarak karta takılı çipi kırparak okudum.
    Aynı şekilde yazmak mümkün mü yoksa eepromun kaldırılması mı gerekiyor?
    Ayrıca buradan programım var https://www.digital-kaos.co.uk/forums/showthread.php?t=288010
    It is always better to remove the eprom and write
    ​information sharing
