good morning,
who can help me identify the speed limit zone on this SID 307 mounted on a Mercedes? With the new map the car goes very well but is limited to 190 km/h. I attach the ORI and MOD files.
good morning,
263C1 switch 001 to 000, 8bits switch
calibra1 (23rd May, 2024)
speed lim already off in file and its 2755A 8b
46696c65207365727669636573
DPF / OPF / EGR / SCR /…..
Thanks to both of you but at least one of you is wrong. Furthermore I believe that each limiter can be set to a value of your choice. So if you wanted to limit it to 150km/h or 200km/h it can't be that there is only one switch.
263C1 is not something about speed limiter, 2755A is switch for Fixed Speed Limiter what I think is speed limiter what you can set with cruise control. I checked the whole dump with damos for anything what is releated Vmax and found nothing.
Maybe it is in the Eeprom. Easiest thing what you can do is coding Vmax with Vediamo for higher value.
calibra1 (28th May, 2024)
