    Nov 2018
    Minecraft
    Default Audi A6 2018 DEF error
    I changed mileage in cluster with DP4(elprosys).
    Had to read key file by OBD, then change eeprom in cluster.
    After edit cluster mileage is OK but DEF showing in display.
    Can somebody correct checksum in eeprom file so DEF is not showing anymore?
    file with needed mileage: OBDII_C12_0319_20240518135419_238619KM
    Or do I need to reflash cluster?
    Cluster: 4G8920935A
    Bosch RB 8 cluster
    NB. when I restore original file still DEF error.
    tried to repair DEF with DP4(elpro), digiprog4(tacho.de) and AVDI Abrites. All failed
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Try reflash odis
    brend's Avatar
    Oct 2015
    Same where
    I gree........ reflash !
    Odis-e if find rigft frf file or diller from server.
    Or try ask same help from member wawanruss . .............................https://www.digital-kaos.co.uk/forum...13#post4319913
    Nov 2018
    Minecraft
    thanks all, will try reflash and report back. Will pm to member wawanruss
    Feb 2011
    What does the support say?
    If I helped, use magic buttons reputation+thanks.
    Best regards.
    Nov 2018
    Minecraft
    No support for this.
    Anyway update for DEF problem. Client decided to go to competition and solved problem there with ODIS and checksum correction. I just received my VNCI 6154A and have installed ODIS-S and ODIS-E.
    They could not wait for me to try.
    If somebody knows how to do it in ODIS, let me know
    Thanks all, and specially @wanaruss he could also solved problem with ODIS.
