Results 1 to 8 of 8
    Jun 2018
    Default Kenwood KDC-M9021SE Mask FOB Key off
    Hello again,
    iīve been searching around but couldnīt find my old fob key for my lovely m9021se.
    Can someone turn off the fob mask key transmission asking at boot ?
    I was thinking about 37h switch to 01 instead of 02, but this is only for service so it turns off after 30 min, also no luck with this in this unit.
    Any other ideas ?
    Here is the original dump form 24c01 located in FM unit.
    Thank you very much in advance
    Aug 2019
    Johannesburg RSA
    Try changing 37h to 23
  3. The Following User Says Thank You to MrRepair For This Useful Post:
    shooting (20th May, 2024)
    Jun 2018
    hmmm, no luck with this
    Jun 2018
    Any other ideas ?
    Aug 2019
    Johannesburg RSA
    Try: Blank eeprom (all FF) and set up test mode as in SM (the nearest to your model I have). Backup eeprom first, just in case..
    kenwood_kdc-m907.rar
  7. The Following 3 Users Say Thank You to MrRepair For This Useful Post:
    Manulu (21st May, 2024), nihad69 (21st May, 2024), shooting (21st May, 2024)
  8. #6
    Jun 2018
    Iīve reset the bin file with FF, normal boot everytthing works.
    After Test mode i got this from bin
    To Check what was in the last line iīve copied the values from the original one.
    Th offset starting at 70 with 4A values are only for the cycles of the power on display, CD eject count etc. Nothing else.
    Any other idea ?
  9. #7
    Jul 2013
    hi, try this file
  10. The Following 3 Users Say Thank You to petronijul For This Useful Post:
    Manulu (23rd May, 2024), MrRepair (23rd May, 2024), shooting (22nd May, 2024)
  11. #8
    Jun 2018
    It worked perfectly, thanks a lot
    But from my perspective itīs not from the original dump right ?
    Wanted to know which values were changed to make it work like this
