Results 1 to 2 of 2
    May 2024
    Default Info on Yazaki48
    I'm trying to get a 2000 Toyota Tacoma dash up and running.
    Instead of the typical please fix this file for me, I'd really like to figure out Yazaki 47 / 48 for myself as I like a good challenge and have a background in maths / electronics.
    I've established that it's not Yazaki17 algo.
    So far I have the following reference milages tested on my unit:
    (hex) = (displayed milage)
    2D08 = 110500
    2809 = 112500
    1409 = 111590
    F80F = 196272
    F80E = 183984
    F923 = 442000
    ???? = 252005 <- the milage I'm trying to encode
    There's clearly a swap-over in the XOR'ed bytes from 00 to FF depending on some value in there.
    There's 96 repeated two-byte copies of the calculated milage in the binary dump, so we can assume that dividing the milage by 96 or a compliment thereof is a likely step.
    Any other info would be really helpful as I'm hitting a wall here trying to decypher this, and I think this info would help out others trying to DIY things a little bit. Thanks!
    May 2024
    Ok, just a follow up. I figured it out. Here goes:
    Take your mileage, divide it by 48 (96 bytes worth of two byte words = 48).
    So 252005 / 48 = 5250 (dec)
    Convert that to hex, 0x1482.
    Swap the byte order (little endian), so 0x8214.
    So fill up all 96 bytes with repeated [82 14] with a hex editor and bam, your mileage is programmed!
