Results 1 to 12 of 12
    Default 38910-80SC0 Suzuki help needed
    I need help with Suzuki RH850 R7F70123 .
    I am reading with original UUprog and every time verify error is present.
    Can somebody please, confirm my reading and clear crash?
    Dump with 8 errors attached:
    Thanks!
    Feb 2011
    Test and report.
    If I helped, use magic buttons reputation+thanks.
    Best regards.
  3. The Following User Says Thank You to km666 For This Useful Post:
    tihiuvek (21st May, 2024)
    I will test and report back!
    Unfortunately does not work!
    No communication with ecu!
    Can somebody please send a pinout in order to connect on table?
    Suzuki swift 2022
    Thanks!
    Feb 2021
    UA ZT
    38910-80SC0
    Small socket
    A - Pin 5=12v
    A - Pin 3=GND
    A - Pin 1=CAN L
    A - Pin 2=CAN H
  8. The Following User Says Thank You to shluxer For This Useful Post:
    tihiuvek (23rd May, 2024)
  9. #7
    Can you please, chek once again GND +canH and CanL doesnot corespond properly. GND is not on pin3 for sure
  10. #8
    Feb 2021
    UA ZT
    take a picture of the sokets
  11. #9
    epd1221's Avatar
    Nov 2011
    usa
    here is pinout
  12. #10
    Feb 2021
    UA ZT
    Quote Originally Posted by epd1221 View Post
    here is pinout
    its ok
    pin5=12v
    pin8=GND
    pin11=CAN L
    pin10=CAN H
  13. The Following User Says Thank You to shluxer For This Useful Post:
  14. #11
    Yes that is correct pinout!
  15. #12
    I successfully connected to srs but no results.
    Maybe somebody has a new clear dump (without crash fromsome other car)?
