    PSAcars's Avatar
    Oct 2015
    HOME
    Default Dodge RAM 1500 5.7L 2022 Dashboard wiring diagram help
    Hello to all. A colleague of mine is having big problems with Dodge RAM 1500 5.7L 2022 dashboard not powering on. No light no nothing. If some one can share wiring diagram of dash to help with troubleshooting. VIN number : 1C6RR7LT5NS189808
    brend's Avatar
    Oct 2015
    Same where
    Start first from this for more anderstand.
    After what , this dash have trable ?
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all.
    Car was imported from USA with front crash and 1 key. The transport company lost the key in arrival. The transport company send is a locksmith to make a new key, in this moment the dash was on and searching key. The locksmith read the car by removing the secure gateway module, and connecting his tool to wiring loom ( not the OBD port ). After read the locksmith connected back all as it was and from there the dash is not working. In Monday we tested the dash in other car and the dash is working fine. I need pinout or schematic to find can lines, power lines maybe missing in the car.
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Today tested the green can bar, all lines are ok, 60 ohm between HI and LO. Still no dashboard.
    Jul 2016
    -Pins 6 ,7,20 are 12 Volt positive +
    -Pins 16,19 are Ground -
    - Pin 11 is Lin bus
    -Pin 12 is Can high
    -Pin 13 is Can low
  6. The Following 3 Users Say Thank You to Etownbrawler For This Useful Post:
    junmab (31st May, 2024), MileageAudit5 (29th May, 2024), PSAcars (23rd May, 2024)
    Jul 2016
    ''Mopar connector repair kits'' website has pinouts for everything and anything Dodge, Chrysler, Jeep from 1997 to 2023
  8. The Following 2 Users Say Thank You to Etownbrawler For This Useful Post:
    junmab (31st May, 2024), PSAcars (23rd May, 2024)
