Results 1 to 14 of 14
    Jan 2024
    Default BMW Z3 2001 km adjustment
    The cluster is a VDO HW 0.3 SW 10
    I want to try to adjust the mileage, and I understand it needs to be adjusted in the coding plug (93c46) and internal EEPROM (93S56) to be able to work.
    On this cluster I've successfully changed the 93c46 with my CH341A, but I'm trying to do the internal EEPROM which is a 93S56 but when I try to find the mileage (should be 395.333), I can't find it. I can find it when I read the 93c46.
    I've desoldered and read the
    93S56 with UPA and attached the dump.
    Where do I go from here? How can I find the mileage in the dump?
    156alfa's Avatar
    Feb 2012
    greetings from italy
    Hello Friend
    too nice friend you are testing with a rather particular car on 93S56
    You will never find the current mileage
    Program plug code 93S56
    Save the Bed File
    5) Upload the saved file again
    Note the Programmed Mileage Example i (km15012)
    Now you can take the internal CIP 93C46
    5) Programming It With The Mileage Bed (km15012)
    If the programmed value has a difference of 16 km
    I would have mistaken about the dash
    I'll tell you that the dash you have in your hands is 41 weeks from the year 1999
    Greetings from Italy
    Jan 2024
    Thanks for your reply!
    You're indeed right, the dash is from a similar car with the same hw and sw number. I assumed the procedure would be the same for the same clusters (both 93C46 and 93S56).
    What do you mean with
    "after the value you have displayed you will have to type it exactly on the
    93s56 if not the value has a change of 16 kms"
    I have powered on the dash and I know the km is
    395.333, I just don't know where to find and change the value in the 93S56 dump.
    Jan 2024
    Willing to pay for a solution. I can't get it working.
    Sep 2012
    you real ml is 379343?
    Jan 2024
    No, it reads 395.333 when powered on.
    Jan 2024
    Attached are both the 93c46 and the 93s56. Does anyone know the algorithm to calculate a desired mileage for the 93s56? The 93c46 I can get with Tachosoft.
    156alfa's Avatar
    Feb 2012
    hello friend
    here is your files
    Try and repost
  9. The Following User Says Thank You to 156alfa For This Useful Post:
    JohnMarston (28th May, 2024)
  10. #9
    Jan 2024
    Grazie mille, i'm putting it back together now and will report if it works.
  11. #10
    Jan 2024
    Hi, it worked!
    Can you do my actual car now?
    Dump is attached. HW is 0.6 and SW11
  12. #11
    156alfa's Avatar
    Feb 2012
    hello friend
    here is your file
    Try and repost
    Next time write down the mileage
    new to the forum and not private thanks
  13. The Following User Says Thank You to 156alfa For This Useful Post:
    JohnMarston (2nd June, 2024)
  14. #12
    Jan 2024
    Quote Originally Posted by 156alfa View Post
    hello friend
    here is your file
    Try and repost
    Appreciate it! Will test it tuesday and report back. Grazie!
  15. #13
    Jan 2024
    hello friend
    here is your file
    Try and repost
    Works, thanks for the help!
  16. #14
    156alfa's Avatar
    Feb 2012
    hello friend
    in the hope that this post will be useful
    to many members of this Forum
