Results 1 to 2 of 2
    DK Veteran easternghost's Avatar
    Mar 2014
    Default Audi edc16cp34 2,7 tdi 2007
    Hello
    After flash programming in bench mode Ktag ori, the ECU is not recognized again using bdm and bench. I will add that the car does not start now. What could be the reason? The software normally said that the recordings were successful.
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    check buk7628 burned
  3. The Following User Says Thank You to vasko For This Useful Post:
    easternghost (21st May, 2024)
