Results 1 to 2 of 2
    Dec 2018
    Default Astra 1.7DTI Tuning Problems, High Pressure Error, remapping, hardcut knowledge quest
    Hi everyone. I have a Opel Astra 1.7DTI (Y17DIT) 2000y (DCWB 208k flash size ECU).
    My car have a 42mm GTX hybrid turbo setup (garret 1549), 48mm original downpipe exhaust without dbkiller.
    We expand intake manifold and you can see this finish status in attachments.
    So, I have some problems and I want many solutions for this problems.
    The first problem is MAP sensor. turbo generates 205kpa+ and throws dtc fault code high intake pressure error and car stay safe mode.
    what should I do? possible solutions; disable dtc (i dont know this) or remap with lower values or change MAP sensor to 300kpa sensor.
    Second problem; i use ecmtitanium and i cant do hardcut at 4800. anybody can help me?
    Third problem; this stage1 file is correct for this setup? if its not safe remap can you help me for this remap.
    My car last log : https://datazap.me/u/serhatboyraz/log-1716303793
    So thanks.
    Oct 2023
    serhat bana özelden yaz sana yardımcı olayım istedigin şekilde dosyanı ayarlar yollarım
