Results 1 to 13 of 13
    Nov 2018
    Minecraft
    Default Suzuki V-Strom 1000DL
    Can somebody tell me if I can use C18 cable from DP4(elprosys) with the diagram found for UPA programmer?
    its for 93C66.
    So
    Upa diagram 1=C18 black
    Upa diagram 2=C18 white
    Upa diagram 3=C18 green
    etc.
    attached is diagram UPA and C18 diagram
    dashradio's Avatar
    Inafield
    Quote Originally Posted by bob191919 View Post
    its for 93C66.
    So
    etc.
    yes you can
  3. The Following User Says Thank You to dashradio For This Useful Post:
    bob191919 (24th May, 2024)
    Nov 2018
    Minecraft
    This is my file VSTROM DL1000 2014: original 72672km need 42800km
    Thanks!
    Last edited by bob191919; 29th May, 2024 at 04:54 AM. Reason: correcting original mileag
    Moderator
    PremierD's Avatar
    Jun 2009
    AF D9 F8 inverted xor FF FF FF = 72650 + 22 FF 80's = 72672 ............. now work it ot for 42800
    although your dump looks a bit iffy should be repeated three times I think you need to read it in 16 bit ..or do a byte flip
  6. The Following 4 Users Say Thank You to PremierD For This Useful Post:
    bob191919 (29th May, 2024), dashradio (28th May, 2024), Johnner (29th May, 2024), jomberykaso (29th May, 2024)
    Nov 2020
    Hi, yr odo is 73672km or 72672 ?
  8. #6
    Sep 2012
    to me give me 72848
  9. #7
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    This is my file VSTROM DL1000 2014: original 73672km need 42800km
    Thanks!
    your file........
  10. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
  11. #8
    Nov 2018
    Minecraft
    Sorry, was typo: its 72672 original
  12. #9
    Sep 2013
    Use my file, then everything will be okay.
  13. The Following User Says Thank You to jomberykaso For This Useful Post:
  14. #10
    Nov 2018
    Minecraft
    @jomberykaso, thanks file is perfect!
  15. #11
    Nov 2018
    Minecraft
    I had again another V-Strom, could somebody please change this file also: Original 44119km need 34119km
    Thanks again
  16. #12
    Sep 2013
    Thanks again
    your file ..........
  17. The Following User Says Thank You to jomberykaso For This Useful Post:
    bob191919 (30th May, 2024)
  18. #13
    Nov 2018
    Minecraft
    Thanks again!
