Results 1 to 3 of 3
    WW
    Default IMMO ECU S122237002A
    need immo off for mini cooper
    ecu siemens vdo
    flash 29F400
    S122237002 A
    Thx.
    Hayssam1's Avatar
    Germany
    Quote Originally Posted by elephantul View Post
    ecu siemens vdo
    flash 29F400
    S122237002 A
    Thx.
    You can try two methods, try method number one first, if it works then you're lucky,
    disconnecting EWS immo boxconnect the two thick cables for the starter EWS
    Please Press Thanks Button and Reput if i helped !
  3. The Following 2 Users Say Thank You to Hayssam1 For This Useful Post:
    elephantul (25th May, 2024)
    WW
    Perfect,everything ok...v2
    Thank you!
  5. The Following User Says Thank You to elephantul For This Useful Post:
    Hayssam1 (25th May, 2024)
