Results 1 to 4 of 4
    auto techniek's Avatar
    Mar 2017
    Default Opel Corsa F key program
    Today tried to add spare key for Opel Corsa F from 2020. It has a psa key With 4A chip.
    Lonsdor couldn t read pin. Tried with autel im608. Did read pin. But no luck to program key. Get message turn ignition off and wait 2 minutes and try again.
    Car with mechanical key
    Any idea if this car can be done or not?
    Verstuurd vanaf mijn CPH2359 met Tapatalk
    Mar 2018
    UK
    spear key is easy with autel just first program the existing key
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    auto techniek (24th May, 2024)
    Mar 2017
    I wil try today
    Yesterday couldn't and get message turn ignistion off and wait 2 minute and try again.
    May be it has a lock time because i did try a few time before with Lonsdor and did not succeed.
    UK
    Done these as spare keys with Autel, Zedfull & Smart Pro. All read pin & program easy with a working key.
    If AKL Smart Pro will pull pin but takes around 35 min then you have 30 minute lock out with AKL.
    KD & Xhorse remotes can be used no problem
  6. The Following 3 Users Say Thank You to the_big_d For This Useful Post:
    auto techniek (26th May, 2024), p1et (24th May, 2024), wuza (25th May, 2024)
