    Nov 2017
    Default VEONEER Peugeot 308 AIRBAG need pinout
    hi, im trying read this airbag module but get error with SMOK J-TAG MULTIPROG
    anyone have pinout to read with VVDI PROG?
    need convert pinout from SMOK to VVDI PROG
    regards
    Peugeot 308 2022 - 9850344180 Veoneer - 9850344180
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    I use smok for this ECU all the time, no issues on my end, although i use different gnd pad, try this gnd.
  3. The Following User Says Thank You to AB4S For This Useful Post:
    VRCars (24th May, 2024)
    Nov 2017
    Quote Originally Posted by AB4S View Post
    i try the GND pad but same error, you put power directly on ecu too?
    i read that when get error need to put power to ecu
    regards
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    Quote Originally Posted by VRCars View Post
    regards
    No i just use vcc from smok to power mcu, there is no need for external power for the ecu
    Nov 2017
    have try several times, no way to read with my smok, maybe is damage, only way now is VVDI prog but no find pinout
    regards
    micromax's Avatar
    South Poland
    tested now. 3,3V without 12V connection
