Results 1 to 5 of 5
    Oct 2016
    Default peugeot boxer 2.2 88kw year 2008 dtc off
    Hello, need for DTC off of this van DTC off, here I attach data
    Peugeot boxer 2.2 88kw year 2008
    ecu visteon DCU 102
    dtc off :P1304
    I can't code injectors and I need DTC off thanks and regards
    Jul 2011
    Portugal
    here you go dtc off
    If im helped thanks and rep.
  3. The Following User Says Thank You to rimljan For This Useful Post:
    garagesport (24th May, 2024)
    Oct 2016
    Hello, it doesn't work, the DTC disappears due to diagnosis, but the light is still on in the dash.
    Jul 2011
    Portugal
    reset in eobd mode. file is original?
    Fault code P1304 on 2.2 HDI engine with Denso injectors. This error is for injector calibration .. solution to solve this problem is to run injector quanity calibration with Texa, Bosh, lexia, Autocom,or,,, diagnostic tools. This engine not only need injector codes written ,but also need fuel presure regulator and injection quanity calibrated, This procedure need about 15 min. if some injector or fuel presure regulator is faulty calibration is unsuccessful !
  6. The Following User Says Thank You to rimljan For This Useful Post:
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by garagesport View Post
    ecu visteon DCU 102
    dtc off :P1304
    Please....................
    PLEASE PRESS THE " THANKS " BUTTON
  8. The Following User Says Thank You to gwiazdamb For This Useful Post:
