Results 1 to 9 of 9
    Mar 2023
    Default kessy continental pin
    Hi, maybe someone can help encrypt continental kessy pin code from vw phaeton 3.0 tdi. I read kessy with vvdi prog. Thanks
    Oct 2013
    Serbia,Mladenovac
    Pin is 49494 try and report
    dimon9555's Avatar
    Oct 2012
    Belarus
    Quote Originally Posted by lesakljucevi View Post
    Of course this is the wrong pin
    P.S. This Kessy from 3.6FSI - not 3.0TDI
    Kessy Continental -139D,-139E,-137F,-137G,7L0909135C,4E0907181 (-181A,-181С)--- (CS,Pin,MAC,Power class,ELV by dump),Passat B6\B7 CCM adapt ELV without old,repair ССM in any state
    Oct 2013
    Serbia,Mladenovac
    VVDI2 say right dump
    Послато са Redmi Note 9 Pro помоћу Тапатока
    Mar 2023
    Pin is not working
    Mar 2023
    Quote Originally Posted by dimon9555 View Post
    can be is it from donor car.
    Jun 2014
    Hi, your correct pin is 47609, so don't forget to use the thanks and reputation button.. good luck...
  8. The Following User Says Thank You to pouleddy For This Useful Post:
    kauciuks (24th May, 2024)
    May 2016
    BRAIN.EXE
    kessy continental not need to desolder eeprom 93C86 it get incorrect data but you need to reading with wire in circuit to get correct pin and cs .
    kessy seimens you need to desolder eeprom to get correct pin and cs
  10. #9
    Mar 2023
    Quote Originally Posted by pouleddy View Post
    I will try tomorrow, i hope everything will be fine, thanks.
