Results 1 to 4 of 4
    seba_m_'s Avatar
    Default Mercedes W213 MD1CP001 scr problem
    Can someone solve the scr off problem? File made with sfiftec, ecudecoder does not work. On the check board, in the ECU there is one P13DF error. Removing the error from the table does not provide a solution, the error is still active. The ECU had a reset before the modification. SCR tank fastened or unfastened, same problem. My hands are already falling. I am giving you the original file and the Swiftec, ecudecoder solution. Can anyone help?
    Jul 2017
    Romania
    Here your file . SCR module disconnected
    File Service ----- Custom Files ------ DPF / SCR / EGR / TVA / Stage ...... Immo / Airbag ETC
    ​Manual File Service WITHOUT prepaid
  3. The Following User Says Thank You to cbvasoft For This Useful Post:
    seba_m_ (27th May, 2024)
    seba_m_'s Avatar
    Quote Originally Posted by cbvasoft View Post
    Thanks - pass??
    Jul 2017
    Romania
    you have PM
  6. The Following User Says Thank You to cbvasoft For This Useful Post:
